I started with this setup:
G540
CandCNC LCTHC
Everlast Power plasma 60C
48v power supply.
SheetCam
Mach3
All wires connected as they should be. Sent my g code into Mach3.
All smiles around the shop. Pressed the torch on button in Mach3.
The torch came on but the motors nowhere. I looked at the G540 and
sure enough a red light.
But when I cleared the fault and ran the job without the plasma on,
it worked just as it should.
I stayed up through the night thinking maybe it was a setting in mach.
I switched the power supply to a 24v. Same thing.
I then took out the LCTHC and installed my Proma THC. Same thing.
Then, I tried without the THC and added a 24v relay. Same thing.
I also disconnected all of the motors. RED LIGHT, RED LIGHT, RED LIGHT.
If anyone knows why this is happening, PLEASE Help Me.
I would be able to go home and get some sleep. And I am sure my wife
would also appreciate that.
