586,075 active members*
3,707 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 1992 Haas VF-2 High Power Ceramic Resistors
Results 1 to 10 of 10
    Mar 2013
    17
    Question 1992 Haas VF-2 High Power Ceramic Resistors
    Here they are:
    My business just purchased a 1992 Haas VF-2. It was having intermittent power issues so in the process of tidying up the electronics cabinet I discovered that these (what appear to be) ceramic resistors were cracked and the wires attached to them scorched.
    They are close to 1 inch in diameter and about 8 inches in length. I am not sure what they are exactly, there closest thing I can find are these:
    http://www.resistorinchina.com/1-8-w...-resistor.html
    http://www.ebay.com/itm/100W-1K-Ohm-...item35c3d8f570
    Mar 2013
    17
    More research leads me to believe that they are Waved Ribbon Wire Wound Resistors:
    http://mf-powerresistor.com/non_flam_rpw.htm
    The electronics people at Reddit suggest that they are used to take up the voltage generated by the motor drives as the motors decelerate. I guess I'll give Haas a call :/
    Nov 2005
    56
    The vector drive sends the power to this when it's switches to regen to slow the spindle. I don't think they are that expensive from HAAS.
    Aug 2010
    579
    Haas Factory Support
    Has this issue been resolved?
    Ken Foulks
    Mar 2013
    17
    Quote Originally Posted by KenFoulks View Post
    Not quite, I didn't have the time to get through to Haas today. My resistors were labeled 10 ohm, but I'm not sure what power wattage rating I need.
    Aug 2010
    579
    Replacement part number is 32-2015 (REGEN RES 20 OHM MAG MACHINES W/MAGN) $58.00. I would strongly recommend a service visit from local distributor to ensure the spindle drive, motor are not damaged.
    Ken Foulks
    Mar 2013
    17
    Thank you
    I'm a bit weary about calling up a service tech because this machine has been refitted with a Fidia control plus the accompanying electronics/drives.
    Jan 2004
    539
    Off topic but how do you like the Fidia control? I thought about that years ago when I was more ambitious.
    It would be worth the service call just to see the look on his face when he seen the screen!
    Gary
    Mar 2013
    17
    The Fidia control is pretty nice, when it's working. The problem is with technical support; there's one Fidia rep in the United States, their support can be slow and expensive. My business partner is convinced that the right thing to do is to convert the Haas back to stock, but that's not a cheap option and frankly it would be a downgrade.
    Because the Fidia control is PC based (Windows NT4) I was able to add the machine to our network (wirelessly). We drag and drop gcode files through the file manager and I even have vnc set up so we can remotely view the machine status from any computer.
    I'd rather have a stock running Haas right now though ;___;
    Feb 2008
    217
    You want cheap power resistors? Electric stove burner elements, I just checked ours small ones ohm out at 40 ohms big ones ohm out at 22 ohms.
    Peer into a new HAAS up topside and see if you can spot one . . .
    We're not in business to make parts, we're in business to make money, making parts is just how we do that.
  1. 1992 Haas vf-2 this is insane...
    By mikemike^3 in forum Haas Mills
    Last Post: 01-05-2012, 03:15 AM
  2. Power resistors,Pls help
    By sa1 in forum CNC Machine Related Electronics
    Last Post: 08-17-2009, 07:11 PM
  3. Need 1992 Haas VF0 drive board ASAP!
    By jrudicel in forum CNC Machining Centers
    Last Post: 09-29-2007, 02:05 AM
  4. Question Power Resistors
    By buddym in forum Stepper Motors / Drives
    Last Post: 11-07-2006, 08:58 PM
