Hello
I am working on a recently aquired 1980s Mori SL1A with a 3t control. When we got the Machine the batteries were dead
and all parameters were lost so I copied the general parameters from our Mori Sl3 and loaded them.
Now the control boots up fine but there is an ER3 machine error and the turret will not index, all other hydraulics like chuck and
tailstock work fine so I checked all the turret limit switches and they are fine also. I can make the turret unclamp by
manually activating the unclamp solenoid but it still wont rotate by activating the rotate solenoid while its unclamped.
Any Ideas what the problem is.
Also when you rapid the machine and let go of the joystick it will coast another 1" or so and any rapid at more than 25% on x or z it gets a servo alarm stating that the numerical value of the error register per that axis has been exceeded.
did I miss a parameter value somewhere or are these electrical or mechanical problems.
has anybody else had these types of problems.
