Hello Everyone,
I made the most disastrous purchase of my life from a CNC company back in September 2012 on a used CNC machine. The company owner made an incomplete delivery (a part missing critical for safe operation) on a machine and promised a 1 year warranty and support. Needless to say I have been left hanging since and all attempts to get my remaining part have been exhausted. I am resolving to small claims court in hopes of some kind of recovery. I am scambling to get this machine up and running and trying to make the best of what I have in hand to get my business going so your help and empathy would be highly appreciated
A customer of mine and I recently spooled up the machine and practiced on some foam using a guitar model the customers developed. One night it worked fine and the next night we came back and noticed a kind jitter/jerking motion in the Z axis/direction when the spindle/head moving mostly in the up direction and rather smooth in the down direction. When we tried to cut another foam guitar it did OK for sometime then suddenly it ripped right into the part. I am almost certain there is something mechanically wrong with the Z motion. I rather sure it is some kind of integration error resulting from the z axis mechanical system. We are using Mach3/PC controller. As a sanity check we set a xyz zero and then moved the head around/up/down manually (Mach3 keyboard commands). When we commanded it back to zero it came back to the correct xy but wrong z (lower than it should have been thus slicing through our parts during run). We were trying to rule out that we did not make some coding error in the CAM so this gave us some confidence.
Any help on where to start would be highly appreciated. From what I can tell the Z axis uses a (formed) ballscrew on linear rails, DC brushed motor, a gear box, and a coupler.
Thank you,
Wess
