587,045 active members*
2,881 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Mori Seiki AL 2 AT W/ 10TF LADDER DIAGRAM.
    May 2009
    106
    HI all, we just purchased a older mori seiki AL2 AT.
    The proble is we got no manuals at all.
    What we need is the Ladder diagram for this machine.
    We have a wiring diagram from other AL 2 machine. But ther is no
    cross reference to the addresses in the ladder.
    This machine had a bar feeder attached before.
    When we do a M10 chuck clamp is good. but M11 uclamp , it is waiting for a fin signal.
    I can see the ladder but there are no comment in there , kinda hard to troubleshoot.
    Any help would be greatly appreciated.
    Feb 2009
    6028
    Quote Originally Posted by jdeere4250 View Post
    Are you sure the chuck prox switches are adjusted correctly on the unclamp cylinder? Is there a toggle switch inside the cabinet to turn off the barfeeder interface? If all those are correct, someone hacked in to the unclamp switch, so with a wiring diagram it should be easy to find.
  1. mori seiki sl2h fanuc 10tf parameters
    By ironofeden in forum Mori Seiki lathes
    Last Post: 12-22-2012, 05:36 AM
  2. Need Mori Seiki CL2000AT ladder and parameter
    By greenery_fr in forum Mori Seiki lathes
    Last Post: 04-18-2012, 06:47 AM
  3. Ladder Diagram for Mori Seiki MV40/Fanuc 6M-B
    By Randy K in forum Mori Seiki Mills
    Last Post: 03-06-2012, 11:21 AM
  4. Need Mori Seiki F-M2 ladder file
    By greenery_fr in forum Fanuc
    Last Post: 12-17-2011, 03:41 AM
  5. Wiring diagram for Mori Seiki TL5 with Yasnac 2000g control
    By frank12933 in forum DNC Problems and Solutions
    Last Post: 04-21-2008, 07:30 PM
