586,129 active members*
2,708 visitors online*
Thread: V25 Install
    Oct 2005
    420
    V25 Install
    Just got V25 today. Would like to install and get using but....should I first uninstall any previous versions before installing? I currently have V24 and V23 installed. Kept V23 because of the HSP. Is there really any need to keep V24?
    Jun 2005
    656
    I have V23 and V25 coexisting nicely on my Win7 box. Haven't tried running V24 as well, but the UI of 25 is much closer to that than it is to 23.
    Dec 2008
    4548
    I have 2 versions of V23, V24 and V25 installed. You may want to keep V24 around for awhile until you are comfortable with V25. V24 will be more point and shoot with no stock/machine considerations.
    Feb 2010
    Keep V24, I still use mine for 4th axis wrap.
    Oct 2005
    420
    Thanks for the suggestions guys. Now that I've had a chance to play with V25 a bit I can see what you mean. I need to take the time and set things up properly. V24 will stay.
  1. Un-install & re-install changes Mach3
    By Beefy in forum Mach Software (ArtSoft software)
    Last Post: 08-01-2012, 09:01 AM
  2. New Install
    By kolias in forum Machines running Mach Software
    Last Post: 05-22-2009, 06:09 PM
  3. USB install
    By MrMazak in forum NCPlot G-Code editor / backplotter
    Last Post: 05-10-2009, 10:57 PM
  4. Install help
    By djmickyg in forum LinuxCNC (formerly EMC2)
    Last Post: 12-02-2007, 03:05 PM
