Hi guys. I'm turning some 2.5 inch delrin at 800 rpm and getting decent finishes with a coated carbide tool. I get an 8 minute run time with a .006 feed and am trying to reduce it if possible. I did a bit of googling and got different answers (surprise) so here I am.
According to Plastics International the speed should be "950-1950 ft/min".
NYTEF Plastics reports "450-600 sfpm" rough and "600-800 sfpm" finish.
Both number are under the turning sections so it's not a mill vs. turning comparison. I feel the gap is way to wide to be correct unless I'm missing something.
Assuming my math is correct, 2,5 X 3.14 =7.85 inches / 12 =.654 ft. So 800 rpm should be 523 ft/min which tells me to go higher in rpms. BUT if I go to PI suggested speeds it will go to 2217rpm.
The median speeds for PI is 1450. So 1450 divided by .654=2217 rpm.
NY has 800 divided by .654= 1223 rpm or half of PI's 2217 rpm.
Which should I go with short of a number of one=off runs as a trial or is that the best route to take?
What are your speeds and feeds?
Man!My head hurts...............
