All the tools in my library have a spindle speed of 5100 (I'm doing small stuff on a Tormach).
Almost all the time, I get the correct spindle speed and feed rate. But, occasionally, I'll have the correct tool but a spindle speed of 200. More occasionally, I'll have the correct spindle speed, but a feed rate of 200.
This is a great way to break tools - and even if I hit the emergency stop in time, it's a great way to waste time and metal (because there doesn't seem to be any way to go back a few steps on the Tormach controller, so I can't continue the job after interrupting it).
Is there any setting in SprutCam that will make it stop doing that????
Yes, I can go through all the operations right before I export, and make sure that the spindle speed and feed rate are correct. But the one time I forget...
Also, is there any way to make SprutCam assign the tool number from the library, rather than (apparently) setting them randomly? (I still haven't figured out its algorithm.) I'd like to have it stop for tool changes whenever I need a change, and not stop otherwise. If it would simply use the tool number that I assigned to the tool in the first place, this would be ideal. Otherwise, I have to set the number individually for each operation and then double-check.
Chris
