I am trying to unhook the barfeeder. I thought I needed to switch parameter 315 bit 7, from a 1 to a 0, but all attemps have not worked. Is this the correct parameter? The lathe is a 2008 SL20, I tried switching the "write enable" pararmeter in the Setting/Graphic, #7 and then E-stop, but it will not allow me to change 315.
Thank you in advance,
