Laser power
50W
Laser type
Hermetic CO2 glass tube
Power supply
AC220±10% 50HZ
Working area 500mm*300mm
Max moving speed 1-1500mm/s
Locating precision ≤0.01mm
Min shaping character Character:3*3mm,letter:1.5*1.5mm
Operating temperature 5℃-35℃
Resolution ratio ≤4500dpi
Control configuration DSP
Data transfer interface USB port
Worktable Fixed table
System environment Files which CorelDraw, AutoCAD can identify
Compatible software CorelDraw, AutoCAD
Cutting thickness 0-10mm(depends on different material)
Color separation Separation of cutting up to 256 colors
Sloping engraving Yes, slope can be designed discretionarily
Hot sale MT3050DII small laser engraving machine
All MORN laser with CE and FDA certificate. Lower prices, higher cost-performance! You can use on your office, shops, home any where!!
