Anyone have any good info on how to calculate Feeds and Speeds for thread Milling? I have to thread mill a M12x.5 hole in Delrin (and soon 6061).
Currently, I'm running a carbide 0.372" 4 flt single profile thread mill at 90 ipm and 5100 RPM. I got this using G-wizard where I set my parameters by calling my tool a 60 deg. dovetail (I thought this was the closest tool they had to my thread mill) with a .5 mm width of cut (my pitch) and a 0.25 mm DOC (I'm running 2 passes).
Is this an accurate method? The Feeds and Speeds work fine in Delrin, but most feeds and speeds do. When I plug the same parameters in for 6061, G-wizard tells me to run at 5100 RPM and 40 IPM. Does that sound right? I've never tried thread milling aluminum and would rather not destroy my tool with too aggressive or soft of a cut. I have no idea if I can actually substitute a thread mill for a dovetail in G-wizard.
