586,471 active members*
3,545 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > How to type "#" on a Yang Eagle Fanuc O-MD
    Feb 2013
    Hi, i made a macro program in my computer and send it to the machine, it's a Yang Eagle 1000 with Fanuc O-MD from 1996. I want to be able to edit the values in the program and then i need to type the sign "#" to alternate the value. Does anyone know how to do it on this machine
    May 2004
    4519
    Trying for programming macro values. If I recall, can't be done on the machine control panel. Must be done offline and then loaded to the machine.
    Feb 2013
    I know it is a "slimmed" control system. So it might not be possible to alternate some characters in the machine control panel as you say.
    Aug 2011
    2517
    according to the parameter manual no's 140-203 set the signals for the keypad to specific letters/numbers/symbols. So it might be possible to re-program one unused key to be a # by setting the correct number. See the parameter manual no's 140-203 for the info.
  1. Helical Beam coupling vs "lovejoy" type?
    By phantomcow2 in forum Linear and Rotary Motion
    Last Post: 04-23-2015, 03:38 AM
  2. Replies: 5
    Last Post: 06-03-2010, 03:18 AM
  3. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
  4. New "Universal" type mills?
    By clockmaker in forum Uncategorised MetalWorking Machines
    Last Post: 08-09-2004, 06:02 PM
