586,999 active members*
2,899 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > cant get rid of solidcam from a part created internally within the solidworks part
    May 2010
    24
    I decided to try creating a new milling operation using the option "internal within solidworks part". Now when ever I open up the part without Solidcam I get the message choose part. I can not disassociate the part from solidcam and also cannot create a new milling operation with this part as always tells me illegal plate when choosing the coordinate system.
    Is there a way to remove all reference from a solidworks part so that I can start over??:drowning:
    I did look all day for a solution, even tried to open the part with a good text editor to see if it might store it in the header...but no luck.
    May 2010
    132
    can you share the file please? maybe i can help, i'm a solidcam instructor
    Moussa
    Jun 2013
    Have you found the solution? I have the same problem since mornig. I even reinstalled solidcam... and nothing.
    all my integrated solidcam parts has that issue. But it's even worse, when I open the part with SW with solidCAM, all I have done in SolidCAM doesn't exist, except extra schetches made by CAM for auto stock model etc. When I'm trying to start again with CAM operation, I have the same problem with "illegal plate when choosing the coordinate system"
    Oct 2013
    153
    External is the best way to keep things cool. In internal mode Always have bugs with no solution and gives more head ache
  1. First SolidCAM part, configurations
    By ASPIDesign in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-01-2011, 04:19 PM
  2. A question on mach fairly broad, More as to Design to physical part being created
    By Craigpat in forum Mach Software (ArtSoft software)
    Last Post: 03-03-2009, 05:49 AM
  3. Replies: 3
    Last Post: 12-11-2008, 02:45 PM
  4. I need help with drawings created from a part.
    By CNCWNTTOBE in forum Uncategorised CAD Discussion
    Last Post: 11-13-2008, 04:21 PM
  5. Replies: 1
    Last Post: 10-21-2008, 06:18 PM
