586,196 active members*
4,136 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Mystery Stepper motor driven FlexiCam
    Nov 2009
    5
    I am in the process of buying an early model stepper motor driven Flexicam here in southern California but I cant find any model numbers or serial numbers on the machine. Can anyone help me figure out what the machine is? The Machine is driven by stepper motors and the table is 1,930mm x 1552mm. The table is cast aluminum and it sits on rubber isolators between the steel frame and the table. Does anyone know what model this machine is or have any experience with it?
    Thanks!
    http://i1289.photobucket.com/albums/...s8ae83da3.jpeg
    http://i1289.photobucket.com/albums/...s8028cb37.jpeg
    Nov 2007
    2466
    from the looks of this it could be a fun project, it looks to be all there. I would consider a change to a more current windows controller like Mach 3 or Wincnc.
    it is not that difficult, can you take some pics of the control box open and up cloes to wire going into the drives, a bit of tracing will answer all your questions and do not unhook any of it without first photographing it well!!
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
  1. Stepper-Driven Power Drawbar
    By SCzEngrgGroup in forum Mechanical Calculations/Engineering Design
    Last Post: 08-29-2022, 01:02 AM
  2. Mystery stepper - need help to identify
    By mbam in forum Stepper Motors / Drives
    Last Post: 08-24-2012, 06:05 PM
  3. How High can a motor be driven with VFD?
    By Adamj12b in forum CNC Machine Related Electronics
    Last Post: 04-16-2009, 04:29 PM
  4. Stepper Driven Spindle Question?
    By Willyb in forum Benchtop Machines
    Last Post: 12-05-2006, 02:12 PM
  5. 120V Stepper - how can it be driven?
    By andy_ck87028 in forum Stepper Motors / Drives
    Last Post: 07-17-2005, 09:16 AM
