587,033 active members*
3,294 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Cutting multiple objects on one stock?
    Jul 2011
    My router's cutting area is 17x11 and I have a 3/4" MDF with those dimensions ready to be cut. I have multiple parts(4) I'd like to cut on one program. I arranged these 4 parts to fit within this 17x11 area in Autodesk Inventor Fusion however when I import the stl file to MeshCam they're arranged very far apart, exceeding my routers dimensions. How can I bring the 4 parts back together within this 17x11 space to be cut? Is this the right way of doing things or should I load one part into MeshCam at a time? This actually will be my first cut so Im not sure if Im missing something obvious or what.
    Apr 2003
    178
    If you change them in Inventor to pack them together tighter then MeshCAM will load and machine them with no problems.
    The nature of an STL file is such that MeshCAM cannot move just one object within the file- multiple CAD objects are combined into a single object in the STL file so MeshCAM can only load them as the CAD program saved them.
    -Robert
    Mar 2011
    61
    UserJ, I do this all the time. I place some verticle bars of stock on the CAD drawing 1/4 " wide that connects all the loose pieces in the interior and use the Meshcam standoffs around the outside. The imported STL has the interior connectors and it imports as one piece. If not for these connectors the interior edges would be unsupported.
    wizzardworks
  1. multiple parts from the same stock- CAD or CAM?
    By WOTDesigns in forum Mastercam
    Last Post: 08-15-2011, 04:18 PM
  2. Copying multiple objects / Tiling Help
    By viroy in forum Solidworks
    Last Post: 06-28-2011, 01:02 PM
  3. Mach 3 problems cutting multiple objects
    By Henry Blignaut in forum Waterjet General Topics
    Last Post: 09-05-2010, 09:35 PM
  4. Cutting out multiple parts from one piece of stock
    By CarlofET in forum DIY CNC Router Table Machines
    Last Post: 05-07-2010, 02:54 AM
  5. Multiple parts 1 stock
    By cnckyle in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-26-2010, 12:07 PM
