586,610 active members*
3,514 visitors online*
Results 1 to 9 of 9
    Jan 2013
    18
    True 4 Axis CNC Software
    Does anyone know of a software platform that can create a true 4-Axis GCode? We have a 4-Axis CNC and all the code we find generates cuts on one plane, then rotates and cuts on another plane. Basically only XYZ work at one time, then the machine rotates the piece (XYZ do not move) then it starts cutting again.
    Is there software that can generate GCode that utilizes all 4 axis at the same time?
    Thank you
    There are lots of them. What is your budget though? Some of them can get ridiculously expensive.
    Jan 2013
    18
    I guess I'm willing to look into it if its available, whats the cheapest, GCode is Gcode...I don't really need something like Solidworks or MasterCam as far as building models, we're more art oriented rather than engineering or machining.
    Jun 2006
    3063
    Look through the list of CAM vendor forums here, visit their web sites to get a sense of what each one does, and then download the demo or trial version of the ones that look most appropriate to you. Try those out and then pick the one that works the best for your needs and meets your budget.
    Or upload a picture of one of your typical projects and hazard a guess on what you can afford to spend. That should elicit a few opinions on potential candidates for your situation.
    Mike
    Dec 2011
    361
    Try the BobCAD demo on our website. It has full 4th utilization like you are looking for.
    May 2004
    4519
    If you are not making airfoils, turbines, or manifolds, true 4/5 axis is rarely needed.
    Jul 2009
    419
    Making art goes the other way, find out what is possibble, then find something for it to do.
    Sven
    http://www.puresven.com/?q=building-cnc-router
    35538
    You might want to check out DeskProto.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Nov 2008
    412
    Cheap alternative CNC Wrapper..
    Forget about global warming...Visualize using your turn signal!
  1. 5 axis cnc versus 5 axis cam software
    By davidsutton in forum Uncategorised CAM Discussion
    Last Post: 05-24-2014, 06:05 PM
  2. True 3D cam software for hobby users
    By Ksoggs in forum Uncategorised CAM Discussion
    Last Post: 03-24-2013, 09:33 PM
  3. True 4th Axis vs Fake 4th axis?
    By microbeast29 in forum Wood Lathes / Mills
    Last Post: 10-25-2012, 03:37 AM
  4. Run-True
    By BTP in forum News Announcements
    Last Post: 09-10-2012, 01:16 AM
