Originally Posted by
zamazz
Yes, that will cost me about 3" of travel. I discussed this in another thread, but the only other way to use double nuts involves cutting far more than I like out of the saddle. The saddle is flimsy enough as is, and cutting two pockets on either side to clear the ballnuts would only worsen it. This way I lose travel, but it should be far more rigid and easier to preload as I can use 4 screws per side instead of two. The remaining 15" of travel should be enough. I know there will be times when I wish I had a little more travel, but that will always occur. It happens on the bridgeport I run quite often. However, 90% of the work will be in a 6" cube in the middle of the table. My goal is to hold .002 in that area, so the increased rigidity is a must.
You should be able to get .002 with the single Ball nut if not better. I see little point in double ball nuts on these machines. Too many other factors are going to cause backlash / deflection besides the ball screws and nuts. As for the amount you would have need to mill of to mount them the other way. I don't think it would have compromised the saddle that much.
Inner Vision Development Corp. - http://www.ivdc.com
Website Design & Development. Shopping Carts, SEO and more!
