Mine has a snap ring on the splined shaft ( the big geared one) on the top side. It really has two snap rings, one to allow the shaft to come out of the bearing, and one to allow the bearing to come out of the housing.
In other words flip this whole assy over and remove the small snap ring from the big geared shaft. Slight force will drive the shaft out. Then you can remove the big snap ring and drive the bearing out the top of housing (bearing will not come out with the shaft). Shaft comes out of bottom, bearing comes out of top.
These bearings went bad in mine just from drawing moisture during shipping. Because they where above the oil fill they rusted and the ones down in the oil where fine.
Jess
GOD Bless, and prayers for all.
