Hello all,
In about 2 months, I bought KL-3025 CNC machine from Automation Technologies Inc (previously Keling), driven by Build Your Own CNC book. Everything went fine. Requested payment to be done on 2 invoices , requested shipping quote, payed, blah blah blah....
Got the router, spindle, drivers, power supply, all happy.
After some time started to find misconceptions from specifications which were on the web site, and the actual received machine.
1. Basically, web site mention 285, got 185 oz-in motors. Raised the question on this, got answer that "That is small machine, and I don't need bigger motors". And I just dropped the question, got no time for innuendos and stuff.
2. Ball bearing screws are marked SFU1610-C7, in real they are SFT1605 - not much problem here, better resolution.
3. As I started to work, machine gives very interesting noises... Investigated deeper, discovered that a Z axis front plate is holding only on 2 screws on the bottom, but not on the screws on top, and vibration which is developed by spindle, shakes the plate. Hey, OK, I'll re-tap the screws and put little bit bigger ones. That will surely hold the plate.
4. Lower linear ball bearing for Z axis from the left guide dont have snap rings and it is falling down. Well, this was the last interesting stuff discovered tonight. Obviously I will have to get new one.
Somebody will say that, "Hey, it's cheap machine! How much money you invest in it, so much you will get.". I say "Yeah, but it's my money, and at least I deserve little bit higher quality from the seller." And choosing US seller, that should at least give little bit more quality control of the product.
However, long story short, question is, following:
How much are you satisfied with your BOUGHT CNC machine.
Thank you,
Vladimir
