2 programs can be used with this method.
It holds one program, and a PTR, but the trick I used was to use /(skip) on each line on first program so it bypassed that and goes to the second one.
The end of the first program should end with /M30
To run the first program block skip is off. To use the second block skip is on.
Rather tiring typing in programs on the crappy vertical console, isn't it?
Of course, if either program uses block skips then this won't work.
