I have completed a JGRO router (Sort of). My problem is in adjusting it. When I originally set up my Workbench, I used a cast-off from work, ad bolted it to the wall. The problem is that it is exactly the same width as the router, and since it is bolted to the wall, i am unable to adjust the back (Far travel of Y Axis) bolts for the X Axis adjustment nuts.
Yesterday, I had finally had it when I was trying to adjust them from an awkward position, and ended up stripping out ANOTHER adjustment block!
Today, after work, i stopped by Lowes, picked up some lumber, and began building a new custom-made Workbench. It is 46X96 inches. perfect to cover with a 4X8 sheet of Plywood.
I have the frame made, and it appears to be ROCK SOLID. I just need some more 2X4's to put in for supports in the middle.
As you can see from the pics, i have a MASIVELY MESSY, CLUTTERED, UNORGANIZED workshop! (chair) It is amazing I don't cut my own arm off, but i am use to it..Mainly it is all storage.
I will also try to post some pics of my Router as it currently stands..
Eddie
