Plotting postional error while running code in mach?
Would it be possible to use Kflop to output the postional error while running some gcode in mach or KmotionCNC.
The motors would be steppers in an open loop and there would be a glass scale on the gantry to measure postion. Kflop would ideally be running in open loop, so not trying to correct the errors in postion just noting down what the errors are in say a spreadsheet?
This would be good for visualising current errors in my machine, so when I make mods to the mechanicals of the router I can see what improvements have been made to the accuracy.
It would also be great to see the difference in the accuracy in the machine when air cutting in comparison to a variety of different materials for example hardwood vs foam.
You could take it a step forward and also place a rotary enocoder on the stepper to measure any missed steps. Would it be possible to output postional error from two encoders on the one axis?
Cheers
Gav
