Not sure if this is the right section but here is my problem.
I have a small DIY CNC router built from extruded aluminum. The table frame is about 28" x 25" inside dimensions. The extrusion on the front and back are 1010 8020. The sides are about 1030 (or 3010. They are about 1" x 2.5"). There is no support in the middle. I have 3/4" MDF down as my base with vacuum channels cut about .200 deep. On top of that I have 1/2" MDF with my grid and all applicable holes. The center of the table is sagging about .030. In order to keep costs down I was planning on getting more 1010 (can't go any deeper as the Y axis hardware would interfere) and running it either along the X (about 25") or Y axis (about 28") near the center. If I run it along the Y axis I can run thicker pieces as the very center is the only part of the Y axis that would have to clear.
Ideally I would just use 1/2" aluminum plate as my table but trying to keep costs at a minimum.
I had thought about getting .250 strips of steel and set them under the MDF but being flat steel I don't think it would offer as much support as say angle iron or extrusion.
Any other thoughts or suggestions on how to do this?
Thanks.
