586,900 active members*
2,793 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Takisawa TS-15 Lathe / Fanuc 6T-B (New(to me) Machine!)
Results 1 to 11 of 11
    Jun 2012
    516
    I'm looking at a takisawa lathe. This machine looks like a pretty good one, although it's really tough to find info, parts, posts about trouble.
    For a start, I'm looking for Fanuc 6T-B manuals. If anyone has them for sale, PM me please!
    Secondly, if anyone has experience on a takisawa lathe, I'd love to hear about it. Any comments? Etc? The machine that I'm looking at is older (im a garage machinist...) but it looks alright in the photos. I'm going to see it in a few hours - I'll have more details later.
    Apr 2006
    3206
    I'm not looking to sell mine, but would consider copying if you can't find one...
    be advised, it's pretty thick
    Jun 2012
    516
    Quote Originally Posted by fizzissist View Post
    Yeah, I'm interested. I haven't found this manual online through the usual 'manual sellers.' It might be pretty pricey to get this thing scanned at fedex/kinkos or whatever. I have access to a good sheet-feeding scanner. I think that the cheapest way to do this would be if I could get you to ship the manual to me, I'd unbind it, scan it, and print both of us a new copy. I'd ship you a new copy and your original back.
    I'm trying to get this manual right away. I've got a second appt. to see the lathe under power next week - and i'll be writing a check for it that day if possible. I have about 5 days to learn as much as possible about the Fanuc 6T and this Takisawa TS-15 lathe. It's a lot of pressure to take in a lot of info in a short amount of time.
    Let me know if this is possible, or if you have suggestions to expedite the manual scanning process. I don't really want to put more than $50 into it - especially because I might find it online and its usually around $25.
    Thanks for your time!
    Apr 2006
    3206
    Quote Originally Posted by mflux_gamblej View Post
    PM me your email.... One quick thing I can do is take pics of the pages that you'll probably need sooner...You can open them up, view, print out what you need...
    Something VERY important to consider will be that the control is also machine specific, and you want to make sure that the parameters are all there.
    95% of the time a buyer will want to fire up the machine, run it through all the axis limits, spindle up and down, reverse, tailstock fwd & rev, chuck clamp,,,, conveyor, coolant...turret index, etc. If it ain't under power, then the value is a fraction of the asking price.
    It's a basic Fanuc control, and the codes haven't changed. Go into jog and jog it. Go into MDI and input a turret index, spindle on, and some simple moves.
    The machine this manual was for was a 1983 Wasino 3axis chucker... and what's funny is that the programs I wrote for it (by hand!) would still function today. What I loved about it was the macro capability.
    24223
    Another aspect that I have covered before, is that when you get it, check all the DC motor brushes, these motors can be very expensive to replace and hard to find.
    The brushes can be had from Helwig Carbon.
    It depends on if it had any preventative maintenance in its time.
    Al.
    Jun 2012
    516
    Thanks for your support guys:
    In terms of fanuc controls - I'm a total newb. I need to know
    • how to initialize / zero the axis
    • how to turn on the spinle (is it m03 s500?) but there might be some other buttons to press first..
    • how to get to mdi mode to program movements
    • how to program some movements (is it simply g02, x1.0, z3.0?)
    • how to set the part zeros for x, and z
    • a simple program to run after all this is setup if in full auto mode
    And before I even get this far, that machine hasn't been under power for a 'while.' The machine comes from a company that went out of business - it's not simply a traded in machine with trouble. that said, you've heard it all before right? 'came right out of a running environment' ha! true or not it doesn't matter in my experience.
    Anyway, the control's batt might be dead - no parameters - and a very delayed test under power before buying. I don't want that. It is possible that the params are on a piece of paper inside the control cab. I don't know - so i need them. This guy isn't gonna sell me this lathe for 1/2 off over some machine parameters.
    Any / all help would be greatly appreciated. In return, I'll take lots of pics and post them so we can all geek out over this new / old as rocks lathe :cheers:
    thanks!
    Jun 2012
    516
    I just read that the fanuc 6 control stores its parameters in 'mbm' memory which doesn't need batteries to survive i.e. it is non volatile. So, if the machine doesn't have parameters - the problem is far worse than a dead batt.
    So, i expect that the params will be there.
    Can anyone confirm that this is true?
    Nov 2006
    925
    Yes it`s bubble memory in a 6TB
    Apr 2006
    3206
    You have email
    Jun 2012
    516
    Update on TS-15 purchasing
    I'm glad I have some used machine buying experience behind me on this one. The lathe boots up with a 401 alarm (servo ready signal not received). it's on the x-axis. I suspect the drive board - the contactor for the big DC to the servo won't pull in. repairs / troubleshooting have been in progress for 2 weeks now and I'm getting impatient. That said, with my first machine, I just knocked a couple thousand off and dealt with the repairs myself. I'm happier buying a proven machine.
    I'll post some pics once I finally buy the damn thing.
    Jun 2012
    516
    Alarm 401 cleared, purchased the Takisawa TS-15 lathe
    Well, I bought myself a CNC lathe. I'll put up some pictures after the rigging happens (feb. 14, for once a valentines day event that I can relate to! ).
    The 401 alarm that the machine was having (fanuc 6tb control) turned out to be a bad x-servo velocity board. I didn't work on the machine myself, so I don't know which component went; a board swap fixed the issue.
    I never imagined that after 6 mo. of running an old CNC mill that I'd be buying an old CNC lathe.
  1. takisawa EX-110 lathe
    By crazycnc in forum MetalWork Discussion
    Last Post: 07-01-2016, 02:50 PM
  2. Consider Takisawa for your lathe needs.
    By DANTEATER in forum Uncategorised MetalWorking Machines
    Last Post: 03-04-2011, 09:15 PM
  3. Fanuc 0T-C Takisawa Lathe
    By Dave1 in forum Fanuc
    Last Post: 06-13-2007, 02:30 PM
  4. Takisawa Tw-20, CNC lathe
    By Masood in forum Mini Lathe
    Last Post: 09-22-2006, 07:35 AM
  5. Takisawa TC-2 Lathe
    By kayleesdad in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-10-2005, 08:37 PM
