587,006 active members*
3,185 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Bridgeport Interact 1 mk2 TNC 2500 Year 1991
Results 1 to 3 of 3
    Apr 2010
    I have recently purchased Bridgeport Interact 1 mk2 (Heidenhain TNC 2500).
    without the Maintenance ore Operating Manual. I have never worked on a Commercial CNC Milling Machine and need to ask some question.
    - "gross over reference point" what does that mean?
    - should the Machine Reference automatically when switched on?
    - how can i reference the Machine Manually?
    Hans
    Nov 2006
    925
    The machine does not reference automatically when switched on.
    You need to pull out the e-stop buttons.
    Press the control on button
    Press the CE button to get to the reference page.
    See how that goes first then come back,but look on this site for the Bridgeport forum and post there as more Bridgeport guys will see it.
    You can download the control manuals from Heidenhain website,all free.
    Apr 2010
    Thanks gridley51 for your reply.
    I know this has been covered before in this Forum put could not find the answer i am looking for.
    I get the error "gross positioning error Z C"
    Pressing Button Cycle start displays a about 20 long numbers after the error message.
    changing the parameter 1140 to the max of 10 displays the message "pass over reference point"
    Pressing now Cycle start will not display these long numbers and machine still don't reference.
    Is it possible to change some parameters to test, instead of changing Motors around as suggested in this forum.
    Those anyone know how to move this tread to the Bridgeport forum?
  1. Bridgeport series 2 interact 4 with tnc 2500
    By miscom in forum Bridgeport / Hardinge Mills
    Last Post: 10-15-2012, 02:46 PM
  2. Bridgeport Interact 412x tnc 2500
    By Takey in forum Bridgeport / Hardinge Mills
    Last Post: 05-24-2010, 10:38 PM
  3. Bridgeport Interact 1 - Heidenhain 2500
    By nycooh in forum CNC Machining Centers
    Last Post: 07-26-2009, 10:40 PM
  4. Bridgeport Interact with TNC 2500
    By bk1955 in forum Bridgeport / Hardinge Mills
    Last Post: 08-05-2008, 12:18 AM
  5. Bridgeport Interact 1 - Heidenhain 2500
    By nycooh in forum Community Club House
    Last Post: 06-25-2007, 09:56 AM
