586,643 active members*
2,743 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Brushless spindle drive using
Results 1 to 10 of 10
    Feb 2004
    813
    Hi guys
    Can I use this
    http://www.copleycontrols.com/motion...pdf/7225ac.pdf
    to spin one of these
    http://www.emoteq.com/quantum.htm size is a 2302
    to max rpm using something like a +/- 10V signal generator
    Thanks for your time
    24223
    It does'nt look like it, unless you have a controller that can supply the Amp with two phase sinusoidal control, and the motor is designed for DC brushless commutation signals.
    Also you require an encoder that can feedback the commutation to the controller.
    Al.
    Feb 2004
    813
    There is a encoder on the motor 2000 line with Halls too
    24223
    Then you will need a dual sinusoidal type output from the Controller.
    Al.
    Feb 2004
    813
    I presume 120dgr apart?
    Jan 2006
    245
    That seems an expensive option for a spindle drive, have a look at this.
    http://www.motioncontrolproducts.com...ds/MCBPlus.pdf
    Also this option does not need an encoder, but will accept one if you want to use an encoder.
    Feb 2004
    813
    I already have the amp; I gave $10 for it; the servo I got 2 for $24
    So it's a cheap option
    Jan 2006
    245
    ok, good luck getting th controller.
    1695
    Where did you get it for so cheap?
    Feb 2004
    813
    The Bay of course
    I got lucky
