587,013 active members*
3,646 visitors online*
    Jan 2013
    End support bearings for acme thread
    I am putting together a clamping device for my lathe to make horizontal bores (see attached). The acme thread is both left and right threaded and arranged to close the clamp when the crank is turned clockwise. I've priced end bearing supports by Nook Industries and was just a little shocked to find a ~$700.00 price tag for 12mm fixed and simple supports. Are there some reliable end supports that will do for less?
    You can get them much cheaper from Misumi, and even cheaper from China, through Ebay.
    Jan 2013
    Thanks Gerry
  1. Max length for an acme threaded rod. End support or fully support the frame?
    By dlpaul in forum DIY CNC Router Table Machines
    Last Post: 03-12-2011, 09:54 PM
  2. acme thread combos and thread mixing
    By calaber40 in forum Linear and Rotary Motion
    Last Post: 05-16-2009, 02:04 AM
  3. Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help
    By pandiyan.innova in forum Community Club House
    Last Post: 11-16-2006, 12:47 PM
  4. Bearings 4 ACME thread?
    By bigz1 in forum Linear and Rotary Motion
    Last Post: 10-17-2006, 12:46 PM
