586,761 active members*
7,633 visitors online*
Results 1 to 7 of 7
    Oct 2005
    34
    RFQ for Sheet Metal Work
    I'm not good with the Drafting Part but attached is a JPG
    2 parasolids can be provided upon request. To be made from .071 6061-T6 Aluminum. Flat pattern size is 24.75" long x approx 5.5". Best option is probably to Laser or Waterjet, then brake form. There are also 2 small hooks in the back, would need 50 of each side.
    thanks,
    Rob
    Edited to add drawing. Can't figure out how to covert to PDF.
    Jan 2004
    3154
    You can't form 6061 (much) it just breaks, you need to look at utility grade aluminum, normal stock is 3003.
    Also you will need to pick .063 or .080 for standard thicknesses.
    I will quote them this way if you email me a dimensioned print complete with a tolerance schedule along with the parasolid (or SolidWorks if you can).
    www.integratedmechanical.ca
    Oct 2005
    34
    Quote Originally Posted by DareBee
    Not true. The minimum bend radius for .071 T6 is .22, for .08 is .25. All bend radii are modeled as .250 so that should be fine. I can e-mail you a parasolid if you leave your e-mail, I'm haven't got the drafting portion of this down so I can't really give you a good print. But .080 would be fine for thickness.
    Jan 2004
    3154
    Rob
    It is true I have bent some 6061 you may have noticed the word (much) in my previous post, it has always been a "challenge".
    I will not quote this job using 6061 material due to my experiences. If you wish to use 1100, 3003, 5052 or 6063 I will be happy to quote, otherwise I respectfully decline.
    Oct 2005
    34
    If you wish to quote me for .080 6063 I would be ok with that. :cheers:
    Jan 2004
    3154
    Rob
    Please pick up my email off of my website and send me the info I previously requested.
    Derek
    Oct 2005
    34
    thanks to everyone that has replied, job has been handed out.
