586,898 active members*
2,801 visitors online*
Results 1 to 9 of 9
    Apr 2005
    17
    Heidenhain ERO 115 encoder problem
    Hello,
    I have a Bridgeport SeriesII with TNC145 and SEM MT30R4-58 motors with heidenhain ERO115 encoders. One of the encoders had problems because of light bulb was blown, so I managed to find a light bulb of that size (T1) and put in place, but now it doesn´t work and as soon as the motor spin it goes to a "X measuring system defective" error in TNC145. Does anyone know how to properly align the encoder as I guess is a alignement problem. Thank you.
    Jan 2005
    1121
    I have taken them apart before and they do not care about alignment
    Perhaps the bulb is not right or you have not connected or assembled something correctly
    >edit< take the cover off of another one and look to see if you can see a difference
    Apr 2005
    17
    Hello,
    I opened a encoder housing from the working machine and i see that the encoder board is a bit different as you can see in the attached pics, first picture is the encoder that is not working S/N 21975203 and the second is the encoder working S/N 21975204. Is it possible that there are 2 types of encoder ERO115 125 and they are not compatible?
    Jan 2005
    1121
    where is the jumper that is on the working encoder?
    why is the resistor jumped out on the non working encoder?
    Apr 2005
    17
    I made a sketch with the encoder that doesn´t work, the jumper in the working encoder is the light bulb that is connected, as it can be seen in the backside of the board, the resistor is part of the light circuit that is isolated from the photoelectric sensors that give the sinusoidal waveform
    Nov 2006
    925
    Alignment does matter and Heidenhain publish a text on how it affects the accuracy of an encoder.
    It`s not the problem here but it is a problem.
    Apr 2005
    17
    have seen the encoder numbers and the working one is a
    ERO115 125 D1 ID nr 217 900 01
    and the encoder that is not working is a
    ERO115 125 H11 ID nr 217 900 04
    Do you know abut the compatibility of this encoders?
    Nov 2006
    925
    If you look on the Heidenhain website you will find the details on these.It is not easy to find but it is there.
    May be quicker calling Heid technical support.It is free but sometimes not all that accurate
    Feb 2008
    4
    Clarkson Company has been repairing these for 22 yrs. The bulb is specific to Heidenhain and Alignment is necessary. Otherwise it's a 50/50 chance of working
  1. Need Heidenhain ERO 115 200 encoder(s)
    By jmccracken in forum Bridgeport / Hardinge Mills
    Last Post: 01-07-2013, 04:09 AM
  2. HEIDENHAIN ROD 271 ENCODER
    By CHANDRU in forum Bridgeport / Hardinge Mills
    Last Post: 05-30-2010, 12:45 PM
  3. Heidenhain encoder
    By N4NV in forum Servo Drives
    Last Post: 06-17-2009, 02:36 PM
  4. Heidenhain Encoder
    By Rupe in forum Uncategorised MetalWorking Machines
    Last Post: 12-09-2008, 10:04 AM
  5. Heidenhain encoder
    By N4NV in forum Gecko Drives
    Last Post: 02-10-2007, 05:24 PM
