Melting? How many RPM? Too many?
Abs blunts a HSS so quick, it will make lots of heat before too long.
If you look at cutter with magnifying glass you will see the rounded off cutting edges.
ABS conducts heat badly so it hangs around. I've found spraying with water helps.
I have found convention milling gives a better finish due to the initial rubbing pressure of cutter burnishes the surface.
Recycling chips, as with other materials, leads to a poor finish too.
Climb milling works OK until the cutter looses it's edge, then it is all downhill.
