I have a cheap 40W CO2 laser engraver that has been working fine until today.
On full power, the ammeter which is in series with the tube, used to show about 15mA when the laser was firing. Now it only shows about 3mA on full power, and the power of the beam produced is in keeping with 3mA.
Immediately before this, I had a little mishap. I was trying to cut some plywood on full power, but I messed up the origins for the work, so the cut actually went off the edge of the plywood. The beam therefore struck the dirty aluminium table that lies about 18mm below the surface of the plywood. Being aluminium, it could quiet possibly have reflected the laser back up through the lenses/mirrors and into the tube.
So I have some questions:
a) Is this possible? Wouldn't the beam passing back the wrong way through the focusing lens, defocus the beam somewhat, so the energy would be dispersed.
b) If this did happen, could it have damaged the tube at all, and if so, how?
b) Are the symptoms of a faulty tube that it no longer draws much current from the PSU?
Any help or advice welcomed!
