586,655 active members*
2,571 visitors online*
Results 1 to 6 of 6
    Nov 2008
    164
    Motors only run one direction
    Just getting the mill up and running for the first time. What I have:
    KL-5056D x 2 (X and Y)
    KL-8070D for my Z
    X and Y motors are KL23H2100-50-4B
    Z motor is KL34H295-43-8A
    KL-DB25RS Breakout Board
    Breakout board and I am regretting this as there is no info that I can find other than a crayon drawing and a diagram showing what pins are.
    Okay so my major issue was that this the motors would not move at all until I realized that the breakout board was preventing the motors from running. Fixed that and setup Mach for the E-Stop.
    Now the motors will only turn CCW....
    Anyone have any ideas? please
    Jan 2010
    35
    We used this wiring
    http://www.automationtechnologiesinc.../KL-DB25RS.pdf
    The dir- is not changing
    Nov 2008
    164
    I replaced my BOB with one from cnc4pc and they work well. I am having a problem with motor tuning although. The do not run at the advertised speeds without them locking up (missing steps and making an awful noise).
    Nov 2009
    15
    Was searching the forums for this same problem, solved mine, so maybe this will work for you too. Keling schematic says 5V to PUL+ and DIR+, and control wires to PUL- and DIR- (from breakout or parallel). Try putting control wires to PUL+ and DIR+, and PUL- and DIR- to ground. Worked for meee!:banana:
    Sep 2010
    did you ever get this figured out? o bought same setup, and i have everything running but motors turn one way, only when the limits are connected? how is the limits supports to work when there are no pins to assign to them?
    Jan 2015
    12
    Re: Motors only run one direction
    I know this thread is old but it's a bear to download that pdf. It seems to have an error so I'm sharing this picture of it.
    Attachment 284128
  1. Stepper Motors Only Move In One Direction???
    By lew90nicis in forum DIY CNC Router Table Machines
    Last Post: 07-04-2012, 02:52 AM
  2. motors run good in one direction
    By edn1 in forum LinuxCNC (formerly EMC2)
    Last Post: 02-23-2011, 06:48 AM
  3. servo motors will not jog two direction
    By thunderbite in forum DIY CNC Router Table Machines
    Last Post: 08-06-2009, 09:07 PM
  4. stepper motors only spin in one direction
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 08-04-2008, 07:28 AM
  5. stepper motors turn only one direction
    By Mike Boarman in forum CNC Machine Related Electronics
    Last Post: 11-24-2006, 11:43 PM
