587,035 active members*
2,818 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > RF45 issue: spindle slow to reach max rpm
    Aug 2012
    25
    I have an RF45 that has developed a problem where in high gear (H3) it is slow (~2sec) to spin up to full rpm. This has only just started happening. It used to spin up to full speed almost immediately. It has been proposed that it might be the starter capacitor. Has anyone else had this issue?
    Feb 2011
    605
    Yes, and Yes. I replaced my start up caps almost immediately after starting machine use. The stock ones were good for maybe 1 hour of spindle time. I got some from Grainger and things were great from there out.
    PM-45 CNC conversion built/run/sold.
    Aug 2012
    25
    Quote Originally Posted by jid2 View Post
    Thanks jid2! I got about 10hrs tops out of mine. I was making a supercharger mount and then on my final step of running some corner rounding it started playing up. I will replace the caps and go from there.
  1. Spindle Won't Reach Speed after Brake On while Spindle Start
    By mflux_gamblej in forum Bridgeport / Hardinge Mills
    Last Post: 06-11-2014, 04:59 AM
  2. No/Slow Spindle
    By JBA Precision in forum Benchtop Machines
    Last Post: 09-20-2012, 05:02 PM
  3. No response from motor at slow speeds. Heat issue?
    By CarlofET in forum DIY CNC Router Table Machines
    Last Post: 05-07-2010, 08:46 PM
  4. Slow Spindle Speed
    By mikemill in forum Syil Products
    Last Post: 01-20-2010, 01:48 PM
  5. Rong-Fu 45 / RF45 Clone Mill Spindle Stop
    By fignoggle in forum News Announcements
    Last Post: 11-06-2009, 06:05 PM
