586,842 active members*
3,142 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Lost my parameters a while ago, now I cant use G10 parameter write
    Sep 2011
    261
    Hello,
    I had a main board die on me a while ago. We got it all fixed and it works fine now. Well, we didnt have a parameter backup and we had to start from generic factory parameters.
    Ive managed to get my machine working pretty much the same as before. I used to be able to use a G10 parameter write in some of my programs, now it doesn't work. I get "010 Improper G-Code" alarm
    Does anyone know how to enable this feature again? I figure its some parameter but I cant find it in the manual.
    CNC Product Manager / Training Consultant
    Apr 2009
    1379
    That is an option parameter. What is your control model?
    Jul 2020
    Re: Lost my parameters a while ago, now I cant use G10 parameter write
    Quote Originally Posted by MCImes View Post
    Hello,
    Hi MCImes
    Did you ever find a solution for your G10 IMPROPER G-CODE issue?
    I have the same problem. The machine is able to output the offsets but if I try to load the offset by program, I get the same alarm like you did. I have an Okuma & Howa 2SP 35H with Fanuc 18T controller.
    Any help would be much appreciated.
    Apr 2009
    1379
    That is an option parameter. Send me a p.m.
  1. Use R parameter to write to tool radius, 840D
    By itstom in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 11-07-2012, 06:47 PM
  2. Can't Write Parameters Fanuc O-TT
    By kmcmillen571 in forum Fanuc
    Last Post: 12-02-2011, 11:04 PM
  3. Fanuc 11m parameter write protect
    By BrianM03 in forum Fanuc
    Last Post: 06-14-2010, 04:17 PM
  4. Parameter write enabling on Fanuc OiT
    By hense in forum Fanuc
    Last Post: 06-02-2008, 11:26 AM
  5. L50 parameter write
    By Bluesman in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2006, 12:49 PM
