586,655 active members*
2,426 visitors online*
    Jan 2013
    Power supplies
    I want to move my CNC into my storage shed. There is no power in the shed and its a fair distance to run a extension cord. I was wondering if anyone knew anything about batteries. To run my drivers for the stepper motor, I need a 24-80VDC and was wondering if I could just wire 3 car batteries in series? I feel like there is some limitation I need to consider but i'm not sure what it is.
    24223
    And the PC and spindle?
    Al.
    Jan 2013
    I was going to switch the computer to a laptop. Not sure what you mean by spindle.
    24223
    If presumably this is a Lathe or Mill, there is usually a relatively large (AC or DC) motor used on the Spindle?
    This either rotates the part or carries the rotating tooling.
    There are a few exceptions I can think of, Robot or Pick and place etc?
    Al.
    Jan 2013
    I was going to try to hook up a cordless drill to work as the mill. I have to move the CNC so i'm trying to keep it as intact as possible but with some changes obviously. Do you know if there is any problem with hooking 3 car batteries together? Also the current output for the battery, I can probably look that up though
    24223
    You can series up three batteries, Automotive battery will supply 100amps for just under 60secs, so i imagine they should run steppers for a while, but not the ideal as you will have to constantly recharge.
    Al.
  1. Power supplies
    By cd_edwards in forum Stepper Motors / Drives
    Last Post: 11-22-2011, 06:38 AM
  2. power supplies.
    By LeeWay in forum Gecko Drives
    Last Post: 05-19-2006, 11:17 AM
  3. power supplies
    By itsme in forum Xylotex
    Last Post: 02-21-2005, 07:40 PM
  4. I need some help on Power Supplies.
    By Tasos_Eco in forum CNC Machine Related Electronics
    Last Post: 02-07-2005, 08:36 PM
  5. These power supplies useful?
    By jlawren6 in forum CNC Machine Related Electronics
    Last Post: 08-26-2004, 02:19 AM
