586,933 active members*
2,650 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > operation console for MicroEDGE/EDGE controllers and FastCNC controllers
    Mar 2010
    141
    Here share our 4/6 torch operation console for Hypertherm's EDGE controllers and FastCNC controllers.
    The operation console includes 1pc operation panel, 1 pc modular circuit 4/6 torch I/O Pcb.
    As pictures show,
    The operation console supports 1-6 plasma/flame torch cutting, dual plasma cutting is ok.
    On operation panel, user may choose any torch cut alone, or choose over 2 torches cut simultaneously, manual up/down control, or auto height cotrol with THC.
    On I/O Pcb,
    CNC controller's input/output, motor drive signals all lead to I/O Pcb, all signals in/out of CNC controller dealed by this I/O Pcb. We specially designed a logic control centre on this I/O Pcb.
    This I/O Pcb supports all Analog signal, Pulse signal servo motors.
    Offer 4/6 torch stations, every torch controlled by a plug torch control Pcb, work seperately.
    Most parts of I/O pcb are isolated, can be repaired/replaced separately in case any IC faulty happens.
    All the CNC system's external wiring completed on this I/O Pcb, standardize the work of CNC system assembly, greatly improve the production speed for large machine maunfacturers, especially in busy season.
    For FastCNC cotnroller, it can be expand to 8 or 12 torches.
    Perfect solution for retrofit project.
    Attached Thumbnails Attached Thumbnails 4.6 torch operation console.jpg   4.6 torch wiring.jpg   operation panel.jpg
    Fiber laser cutting machine
    http://qlaser.en.alibaba.com/
    Mar 2010
    141
    attached is EDGE's I/O, Drive interface with the 4/6 torch I/O Pcb's I/O and drive port.
  1. Modular 4/6-torch IO card for EDGE/MicroEDGE
    By larryy1022 in forum News Announcements
    Last Post: 03-28-2012, 09:34 AM
  2. Edge Pro vs MicroEDGE
    By Mastikhor in forum Hypertherm Plasma
    Last Post: 06-12-2011, 10:21 AM
  3. Need some help with controllers
    By Evil Tsi in forum Servo Motors / Drives
    Last Post: 05-20-2011, 02:54 AM
  4. Controllers
    By Russell@Iscar in forum Fanuc
    Last Post: 08-21-2008, 02:03 PM
  5. DIY Controllers
    By biotech1 in forum Mechanical Calculations/Engineering Design
    Last Post: 12-02-2006, 11:56 AM
