Greetings. I am experiencing lots of problems with runout on a micro drill adapter (sensitive drill chuck, slip chuck). My unit has an Albrecht keyless chuck mounted via a J0 taper to the finger fed adapter. Excellent feel for small diameter drills, but I find each tool change requires tapping the chuck around on the mount taper to eliminate runnout. My shop partner has a nearly identical unit from a different manufacturer that behaves in the same way. Am I expecting too much or is there some secret for repeatable concentricity between tool changes. (Running tool in a new R-8 adaptor on a Bridgeport with pristine spindle bore.) Thanks in adavnce
