586,740 active members*
2,543 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCAD V25 4-Axis users. Go 4-axis Pro?
Results 1 to 7 of 7
    Jan 2011
    380
    Lightbulb BobCAD V25 4-Axis users. Go 4-axis Pro?
    Hey all,
    Will be installing a newer Haas VF3 in our shop soon. They did get us a 4th axis rotary table we had requested. Currently I use BobCAD V25 and it has 4-axis standard. Just wanted to ask if anyone out there is using 4-axis Pro? What are some reasons I would want to go pro instead of standard. What are the differences if used on a rotary table axis?
    Thanks for your time
    Mar 2012
    1570
    Tony,
    You have to understand that going to the 4 axis pro will also effect all the 3D programming you can do and how you simulate your prats. The 4 axis pro is the multi axis software which provides 7 surface based tool paths that you can use in 3 or 4 axis and also offer full machine simulation.
    The 4 axis standard has indexing wrapping and rotary right? So for the indexing you just pick a surface or UCS to index to and cut from there. Use the wrapping is really only 3 axis cutting where 1 of the axis is substituted for a rotary movement. And Rotary tool path is where you are working with a solid and program along or around the part.
    The 4 axis pro will program X Y Z A all at the same time. So it's true 4 axis. If you are going to be programming parts where all axis need to be moving at the same time, then 4 axis pro is the way to go. At the same time these 7 tool path options are very powerful and will give you more options for cutting in 3 axis. Like flow style or undercutting. For the type of machine you have I would highly recommend the 4 axis pro upgrade.
    The following video clip is from MasterCam | MasterCam Tutorial Training | SolidWorks Tutorial | SolidWorks | Cad Cam They offer on line training on mastercam. I know why I am showing a link for mastercam right, well Karlo Apro wrote the book on 5 axis programming, no really you can purchase a copy from here. [ame=http://www.amazon.com/Secrets-5-Axis-Machining-Karlo-Apro/dp/0831133759]Secrets of 5-Axis Machining: Karlo Apro: 9780831133757: Amazon.com: Books[/ame] he is in this webinar talking about 3 4 and 5 axis programming. It's about an hour long but it's worth watching. I think it will better help you understand advantages of machine simulation and 4 and 5 axis programming.
    [ame=http://www.youtube.com/watch?v=SqV_BWM6phY]Secrets of 5 Axis machining webinar with karlo Apro - YouTube[/ame]
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Mar 2012
    1570
    4 axis rotary sample code:
    Code:
    N22 Z1.5115 A13.404 F158.9728
    N23 Z1.5386 A14.681 F153.4893
    N24 Z1.5675 A15.957 F148.0009
    N25 Z1.5828 A16.596 F286.4455
    N26 Z1.5984 A17.234 F282.6766
    N27 Z1.6146 A17.872 F276.6165
    N28 Z1.6314 A18.511 F270.4845
    N29 Z1.6485 A19.149 F266.8796
    N30 Z1.666 A19.787 F262.1636
    N31 Z1.6845 A20.426 F253.9683
    N32 Z1.704 A21.064 F245.9593
    N33 Z1.7209 A21.702 F261.8401
    N34 Z1.7376 A22.34 F261.6942
    N35 Z1.7526 A22.979 F271.7487
    N36 Z1.7682 A23.617 F266.3334
    N37 Z1.7818 A24.255 F278.5564
    N38 Z1.7961 A24.894 F271.6626
    N39 Z1.8085 A25.532 F282.9161
    N40 Z1.8214 A26.17 F278.1024
    N41 Z1.8327 A26.809 F287.0084
    N42 Z1.8443 A27.447 F283.249
    N43 Z1.8544 A28.085 F291.0584
    N44 Z1.8648 A28.723 F287.6551
    N45 Z1.8737 A29.362 F294.6629
    N46 Z1.8831 A30. F291.2289
    N47 Z1.8908 A30.638 F298.0426
    N48 Z1.8991 A31.277 F294.424
    N49 Z1.9056 A31.915 F300.8061
    N50 Z1.9128 A32.553 F297.0556
    4 Axis Pro morph between 2 curves sample code
    Code:
    N15 Y1.2107 Z-1.3855 A155.82 F490.3151
    N16 Y1.186 Z-1.4183 A154.251 F487.5002
    N17 Y1.1603 Z-1.4506 A152.674 F484.8755
    N18 Y1.1336 Z-1.4823 A151.088 F482.4412
    N19 Y1.1058 Z-1.5135 A149.496 F480.1973
    N20 Y1.0547 Z-1.5666 A146.679 F271.5458
    N21 Y1.0007 Z-1.6174 A143.845 F269.8271
    N22 Y0.9439 Z-1.6658 A140.995 F268.443
    N23 Y0.8845 Z-1.7114 A138.135 F267.3933
    N24 Y0.8504 Z-1.7356 A136.538 F478.7227
    N25 Y0.8156 Z-1.7589 A134.938 F478.1939
    N26 Y0.7801 Z-1.7812 A133.338 F477.8517
    N27 Y0.744 Z-1.8025 A131.737 F477.6958
    N28 Y0.7073 Z-1.8227 A130.136 F477.7265
    N29 Y0.6701 Z-1.842 A128.536 F477.9436
    N30 Y0.6324 Z-1.8602 A126.937 F478.3473
    N31 Y0.5943 Z-1.8773 A125.34 F478.9373
    N32 Y0.5589 Z-1.892 A123.877 F522.6456
    N33 Y0.4873 Z-1.9186 A120.959 F262.0973
    N34 Y0.4148 Z-1.9415 A118.055 F263.387
    N35 Y0.3417 Z-1.9606 A115.169 F265.0189
    N36 Y0.265 Z-1.9764 A112.176 F255.5963
    N37 Y0.225 Z-1.983 A110.626 F493.4586
    N38 Y0.185 Z-1.9885 A109.084 F495.9772
    N39 Y0.1451 Z-1.993 A107.551 F498.6823
    N40 Y0.1053 Z-1.9963 A106.026 F501.5739
    N41 Y0.0657 Z-1.9986 A104.511 F504.652
    N42 Y0.0263 Z-1.9998 A103.005 F507.9166
    N43 Y-0.0129 Z-1.9999 A101.508 F510.982
    N44 Y-0.0852 Z-1.9976 A98.743 F276.5974
    N45 Y-0.1582 Z-1.9916 A95.946 F273.4255
    N46 Y-0.2316 Z-1.982 A93.119 F270.5959
    N47 Y-0.305 Z-1.9687 A90.267 F268.1084
    N48 Y-0.3458 Z-1.9596 A88.67 F479.1125
    N49 Y-0.3865 Z-1.9493 A87.067 F477.1571
    N50 Y-0.4271 Z-1.9379 A85.459 F475.3921
    N51 Y-0.4674 Z-1.9253 A83.845 F473.8173
    [ame=http://www.youtube.com/watch?v=SIsnOxB043w]4 Axis Rotary vs Morph Between 2 Curves - YouTube[/ame]
    Al DePoalo
    Router G and M code
    Hi there,
    Can anybody give me a link for router G and M codes.
    I need to lean a little bit more about router codes.
    I am trying to find information what does G8 do. Or C0.
    What P1 and P0 do for the routers.
    thanks in advance
    Vlado
    Jan 2011
    380
    Thanks Al. Guess I will be looking to get an upgrade to Pro then. Will watch for a deal on it and let our sales guy know. Company finally spent money to get the machine we wanted, don't want to drop another purchase on them right away
    Jan 2011
    380
    Quote Originally Posted by VladoNeykov View Post
    Hi there,
    thanks in advance
    Vlado
    Not sure if you are asking your question in the right forum. This is for BobCAD CAM software help.
    You might want to look here: CNCzone.com-The Largest Machinist Community on the net! - Powered by vBulletin
    Thats the area for woodworking machines and routers and I think your question will get more help there
    Dec 2011
    361
    Here is a link for a list of G and M codes, I can definitely say, Wikipedia pretty much has everything.
    G-code - Wikipedia, the free encyclopedia
  1. Dyna Myte / Yuasa 550-046 4th axis users
    By mfgbydesign in forum Dyna Mechtronics
    Last Post: 12-15-2012, 01:24 PM
  2. BobCAD CAM V25 4 Axis Standard
    By aldepoalo in forum BobCad-Cam
    Last Post: 09-28-2012, 12:45 PM
  3. Rotary Axis help with Bobcad
    By foustchoppers in forum BobCad-Cam
    Last Post: 02-07-2012, 05:39 PM
  4. Any 5 axis water jet users out there?
    By klrskies in forum Waterjet General Topics
    Last Post: 03-17-2011, 01:26 PM
  5. 4th axis support in BobCad
    By P40Sortie in forum BobCad-Cam
    Last Post: 09-18-2006, 07:58 PM
