There are a number of threads that are using timing belts and pulleys in the implementation but little information about why the particular belt and pulleys were selected. Looking at belts and pulleys there seems to be a number of characteristics:
- Pitch - 2mm, 3mm, 5mm, 8mm, ... all the imperial pitches
- Tooth Profiles - tangential, round, various flavors of 'improved round', etc.
- Width - multiple choices
- Pulley size - the number of engaged teeth vs. the higher belt speed that is associated with "a larger pulley means more engaged teeth".
- Other items that my inexperience knows nothing about
I am wondering what process others have used to determine what belt and pulleys they would use.
What ever process you used --- be it "its what I had on hand" thru "this is what someone else used" and on to "put criteria X, Y, Z into spreadsheet ABC and got answer LMN" --- I and possibly others would like to know how the decision was made.
If a 'reference implementation' would help with the responses then: "A large RF45 table ... 1000mm by 260mm travel, 5 pitch lead screws, ~800 oz/in servos for X and Y and 4 pitch lead screw with a ~1100 oz/in servo for Z."
Any thoughts or real world experience would be appreciated.
Arvid
As a side note, please lets not get sidetracked with a "just use steppers" discussion.
