Ok guys I finally got time to finish the scribe on the plasma table and get it working perfectly. The plasma table to took a backseat for a few months after I was laid off May 30 from my engineering job then was moved across the country to NC for my new job that I started July 9. I'll let you guess where I got a job at. On to the fun.
Parts list.
Chicago pneumatic scribe CP-9361
THK HSR20 rail
AVS-5312-120A 4-way (2 position) Use this one for a double acting cylinder
AVS-3312-120A 3-way (2 position) For supplying air to the scribe
SBC-14N Silencer cones. (Brass looking things)
MS14-14N - MALE STRAIGHT 5/PK FOR 1/4iN OD PUR/NYLON & 1/4in MNPT
#10-32 port to 1/4 OD tubing - used on the 7/16 cylinder
ME14-10N - MALE ELBOW 5/PK FOR 1/4in OD PUR/NYLON
ME14-10N - MALE STRAIGHT 5/PK FOR 1/4in OD PUR/NYLON
PU14BLU100 Blue tubing
PU14RED100 Red tubing
A07060DN 7/16 Bore double acting cylinder 6in stroke
Scribe regulator AR-323 - REGULATOR, 1/4 IN NPT, 130 PSI, GAUGE, BRACKET
Air cylinder regulator AR-322 - REGULATOR, 1/4 IN. NPT, 60 PSI, GAUGE, BRACKET
Plus a random spring from Home Depot since my air valves will only activate above 10 PSI so I needed way to up the pressure without putting to much pressure on the scribe.
Regulator and valve setup.
