586,305 active members*
4,026 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Mills > Emco F1P-CNC error alarm please help
    May 2012
    4
    Question Emco F1P-CNC error alarm please help
    I have an emco F1P CNC mill that comes up with an error code 95 'work piece catcher not ready'. The machine is not fitted with a work catcher and I cant reset it has anyone come across this before or have any ideas how I can clear the error code. Thanks :wave:
    The software version is AC03.00/DC03.10
    May 2012
    4
    HELP
    PLEASE PLEASE someone out there must know the answer to my error code any little bit of information will be greatfully recieved:violin:
    Mar 2007
    4
    If your mill was the woodworker version of the Emcof1, it may have originally had a vacuum table to hold the part being worked. Perhaps a connector needs to be plugged or unplugged. Does the usual code clearing "input + reverse" have any effect? Perhaps the Yahoo group "Emcof1mill" has info about this.
    May 2012
    4
    Error Code
    Spinwheelz,
    Thank you for your time and input I have tried what you suggest but to no effect, oh well I will try the Yahoo forum as you suggest and see if anyone else has any ideas. By the way my machine is not a woodworker version.
    Thanks again.
  1. Replies: 27
    Last Post: 02-09-2022, 05:10 PM
  2. Emco Maier 342 error
    By larrydpm in forum EMCO Lathe
    Last Post: 12-12-2011, 07:30 PM
  3. Emco 340 Alarm
    By WIRE CUTTER in forum EMCO Lathe
    Last Post: 04-24-2011, 05:12 PM
  4. Error 414 Z axis error detect- servo alarm
    By andywids in forum Fanuc
    Last Post: 07-09-2009, 04:33 PM
  5. Error 414 Z-axis error detect servo alarm
    By andywids in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2009, 03:56 PM
