586,951 active members*
2,754 visitors online*
Results 1 to 9 of 9
    Jun 2008
    1511
    Hitachi Seiki Alarm Help!
    It is a HItachi Seiki VK55II VMC with Seicos MIII control. There was a power outage. Now at power up there is alarm (2AC5)APC Slave Fuse Trip. The description of the alarm in the book says Fuse Of APC Slave Unit Has Been Blown. I can not seem to find anything on this. Has anyone seen this? Thanks for your help!!
    Aug 2011
    6
    I have purches a hitachi seiki HC400 machine.
    I need your support.
    Now have a problem in the plc (M16 II).
    There is 2 alarms are coming.
    1. SUM CHECK ERROR.
    2. BATTERY ALARM.
    Please help us for clear this alarms.
    I checked the power supply in PLC. (+15V, -15V, 5V 24V and Battery Volt) it's all ok.
    But the alarm does not clear.
    Please Help Us.
    Thanks & regards,
    Jun 2008
    1511
    It has been awhile but according to my old notes you need to do the following for the SUM CHECK error.
    1. Press F1(SEQUENCE) ->Press F2(DATASET) -> Press F4(TABLE) -> You will see “Constance Byte Table 1
    2. Type 0 0 (in the 1. 00) -> Press INPUT -> You will see Parameter Write Enable SW On
    3. Turn on WRITE ENABLE SW that is on MICON16-2 board in control panel
    4. Press F6(END). -> You will see Write Enable SW Off
    5. Turn off WRITE ENABLE SW
    6. Press F6(END) -> Press F1(SEQUENCE) ->Press F3(PROGRAM) -> You will see Parameter Write Enable SW On
    7. Turn on WRITE ENABLE SW that is on MICON16-2 board in control panel
    8. You will see top line of ladder automatically
    9. Press F2(ALTER) -> You will see ___(Cursor) on screen.
    10. Press F4(STORE) -> Press INPUT.
    11. Press F6(END) -> You will see Write Enable SW Off
    14. Turn off WRITE ENABLE SW
    15. Turn off NC power -> Turn on NC power
    This may or may not work as I said before it has been a long time and some things may need to be done in different sequences. Give it a try and let me know if it works.
    Good luck,
    Stevo
    Aug 2011
    6
    Thaks. I will check my machine and get back to you.
    Aug 2011
    6
    Hello,
    I tried my machine as per your instruction. After the step no 7 Turn on WRITE ENABLE SW that is on MICON16-2 board in control panel. it will ask key ward please____. I don't the key ward please support for the key ward.
    Thanks once again.
    Jun 2008
    1511
    It should not be asking you for a password. IIRC this happened to someone else that I was helping and they had to do the procedure a few times before it would take and not ask for a password.
    Stevo
    Aug 2011
    6
    Hello Now I lock an other alarm
    Power supply down +15V.
    Power supply down -15V.
    Please help me.
    Thanks.
    Jun 2015
    Re: Hitachi Seiki Alarm Help!
    hi I was hoping somebody could help me with my alarm code on my Hitachi hg 800. I was doing a automatic pallet change m60 when half way through the cycle the e stop triggered results in power to cut out and unable to recover pallet to table side of the machine, ive tried the sw1 switch maintenance mode but it wont let me do anything because off another cc alarm in red that states parameter write enabled please can some one point me in write direction also how to solve these two problems thanks
    Hi, I have a Hitachi Siki model h cut 230 m. Alloacted page is limited. How can I increase it?
  1. Hitachi-Seiki 4NE-600 Motor Alarm
    By jbmozer in forum Mori Seiki lathes
    Last Post: 04-24-2015, 11:04 AM
  2. hitachi seiki alarm
    By Hasse79 in forum Hitachi Seikis
    Last Post: 03-17-2014, 11:20 AM
  3. HITACHI SEIKI 3NE 300 LATHE ALARM 401
    By jordan123 in forum MetalWork Discussion
    Last Post: 03-31-2011, 02:57 AM
  4. Hitachi Seiki alarm code help
    By atrus in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-29-2008, 03:49 PM
