586,983 active members*
4,298 visitors online*
    Sep 2009
    68
    fanuc 10M Cycle start wont work
    hi
    the machine is VMC Victor V center 4 with Fanuc 10M,
    there was a power failure while the machine was on and working, after the power got back I turn on the machine a everything look ok until I tried to run some of the programs, the machine can do a zero return, the mode switch is working also I can send and receive programs in the machine memory etc.
    but when I tried to start a program the Cycle start button wont work!
    i even tried in MDI mode
    I inserted
    S1000;
    M3;
    and tried on the soft panel button "START" and I get on the screen "HOLD" and the Cycle stop button lights red and the error led lights up also
    any suggestion about what is wrong??? :drowning:
    thank you in advance
    Oct 2005
    332
    No error code is displayed?
    Did you checked the status of the spindle amplifier?
    Vladimir hello,
    You must check in lader for reason why cycle does not start,
    or check in diagnostics does tool is clamped , door closed e.t.c.
    regards djordje
    Aug 2007
    793
    check ladder line corresponding G0.5 (*SP) signal. when all conditions are exist this signals becomes ON. also you may see it on diagnostics screen
    Sep 2009
    68
    problem solved it was the tool clamp sensor
    thank you all
  1. Fanuc O-MC wont start
    By AJA1 in forum Fanuc
    Last Post: 11-03-2012, 09:50 PM
  2. fanuc system 6t (RAMbold) wont start
    By leiryll in forum Fanuc
    Last Post: 10-13-2012, 01:54 PM
  3. Fanuc 6T wont start up
    By dansteinmetz in forum Fanuc
    Last Post: 08-01-2010, 03:58 AM
  4. Fanuc O-TT cycle start not working?
    By BryCAM in forum Fanuc
    Last Post: 06-05-2010, 11:20 AM
  5. Cycle Start output on Fanuc 15-MA
    By davider in forum Fanuc
    Last Post: 02-14-2008, 04:18 PM
