I've just run a fly-cutter and a 3/8 end mill over a ~2 inch cube of aluminium to tidy it up. Both left a ridge which I could feel with my finger along the edge of their cut. "No problem", I thought, this sounds like the mill needing to be trammed. I haven't done that since I bought it, and it has been hauled around a bit. In fact, I'm not sure if it has ever been trammed.
So I grab my DTI and some ground blocks, set them up to measure the x-axis... and it appears to be perfect. I do the same for y and again it is perfect.
Now, I'm slightly suspicious I'm doing something wrong, but I can't see what. I've watched NYCCNCs tramming video on YouTube, and I am doing exactly the same thing. My DTI doesn't have a very long arm, so that probably isn't helping. But if tram appears to be correct within a very small figure - is that likely after moving the machine twice? Wouldn't the move plus a different floor throw it off by twisting the stand slightly?
Something else I've just noticed too - if I turn the jog wheel full-speed +/- on the x-axis, occasionally it moves at a slower rate before speeding up. The slow rate seems to be the "second-fastest" speed. There isn't an intermediate acceleration, it just goes second-fastest, then after 1/2 second or so goes to full speed like it should. Has anyone else seen this behaviour? Edit - I strongly suspect the new USB hub I'm using is the cause of this!
Luke
Edit - I'm going to keep the DTI in the spindle, and run it up the side of a square on the table, and see if that tells me anything about the spindle-table relationship. I'll also run the DTI along the table surface and watch what happens.
