Indirectly, I will. But I'm not going to lock the user into a certain size.Could you do that, that is, limit the size of the stock so the stock would not be gouged.
Yes. What I've shown is only for equally spaced half blind dovetails. When I get that how I want it, then I'll move on to unequally spaced, which is far more complex.Another idea: Is there some way you can make it so that the dovetails would not necessarily be evenly spaced?
With CNC, you never have to trade off accuracy or repeatability. But as a developer, you can't make everyone happy either. So while I'll listen to everyone's opinion, they can't all be obliged.There seems to be a bit of a trade off here between the three
I really like using polyurethane (gorilla) glue for dovetails. It gives you a lot of working time, and actually acts as a lubricant, aiding in assembly. You just have to be extra neat with it. But if you get any foaming in the box, it's easily cleaned up with a sharp chisel when cured.The glue forces speed on you as it sets up relatively quickly,
My goal is to offer as much flexibility as possible, within reason.I suggest thinking about the whole process and the CNC cutting the dovetails as part of that process, and not just thinking about the CNC cutting isolated from the making the final product.
