1090 keyboard interface board - video probs (still!!!)
Any thoughts on the 1090 board causing my garbage screen on this 1994 VMC-15XT ?
(so far, video, motherboard, CPU and CPU interface, and even the little connector board all tested and/or replaced). I have also cleared memory and reset all parameters. Three monitors have done it, and the flat screen mounted now is not suspect at all.
I have accidentally discovered a temporary workaround that may help with clues. If i power up and hit the green button, I almost always get the garbage fuzzy screen. LEt it sit 20 minutes, power cycle again and I get video every time so far. THe video is occasionally slightly fuzzy, and occasionaly crystal clear.
One board left alone so far is the 1090-3A. SHould I get this tested? Does that make sense? Also, what others are compatible? (-3, -3B, etc. and what are the differences?)
THanks for any help to wake me up from this 7 month nightmare! haa
Scott
http://www.scpconcepts.com
