586,655 active members*
2,899 visitors online*
    endmill set with 6mm shank
    Hi all,
    Can any one point me to set of end mills with 6mm shanks? something like 1mm - 6mm end mill all with 6mm shank. :banana: build done now time to make some dust. I have an old Bosch router with only 6mm collect.
    Cheers
    Apr 2009
    5516
    I would look into the PreciseBits collets, which should give you some options. I have never seen a set like you describe, though it might exist somewhere. Amana sells different reducer bushings.
    Nov 2006
    1036
    I did a search on Amazon for "Amico 6mm shank end mills". This is what I got: (link didn't work but, hopefully, the search will)
    Hope this helps.
    Apr 2002
    5003
    You can buy these sets from some not real premium sellers. If you have a router than I think you use it only for wood or plastics. In these case nearly all carbide endmill sets will do. But dont try steel tools.
  1. Replies: 2
    Last Post: 10-07-2011, 10:56 PM
  2. 1/8" shank endmill holder
    By CNCMike in forum MetalWork Discussion
    Last Post: 10-24-2008, 04:58 AM
  3. ?? Making a endmill shank smaller
    By whiteriver in forum MetalWork Discussion
    Last Post: 09-06-2005, 04:50 PM
