586,383 active members*
3,545 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > lathe coolant/cutting fluid ?
    Jun 2005
    141
    I am in the process of building a upgraded (for me) lathe headstock with a larger center bore of the spindle to do some deep hole drilling. I have never had a power fluid delivery system, in the past I just use a oilier can with cutting fluid but now I am thinking I want/need a constant flow of cutting oil (not a mister) which should also cool and remove chips.
    When I look up store bought lathe coolant systems they all reffed to "coolant" (obvious with the name I know) but I am thinking I don't want "coolant" but rather cutting oil is this way of thinking wrong should be regular oil since that much has to get sprayed over my lathe bed ? Will these coolant systems pump cutting fluid instead of coolant fluid ?
    Apr 2006
    3206
    If you're going to use HSS tools, use a good cutting oil, like for screw machines.
    If you're going to use carbide, then use a water soluble.
    If you use water soluble as a flood coolant, then be prepared to keep your coolant meticulously clean, and clean the lathe frequently to deal with the ensuing rust.
    If you don't want the mess of either, don't use either.
    Jun 2005
    141
    most of what tooling I have is HSS but have some carbide . The rust issue even with the "rust inhibitor" in the coolant products is one thing I was wanting to avoid I would rather use OIL and not have that extra worry.
    Will those store bought coolant systems pump the cutting oil if not what is the proper name of a system that will so I know what to look for?
    Apr 2006
    3206
    I've used Graymills pumps with both... the oil just moves a lot slower. A mechanical impeller pump should handle either, question of whether the motor will stall... That said, call the mfg and ask!
    Jun 2005
    141
    ok thanks
  1. What cutting fluid do you use?
    By nateman_doo in forum Benchtop Machines
    Last Post: 02-10-2012, 08:37 PM
  2. Internal Spindle Coolant Fluid
    By TPdrums in forum Maintenance DIY Discussion
    Last Post: 12-16-2011, 04:28 AM
  3. Multiple tapped holes on NC, tapping fluid, or is coolant ok?
    By Brian FRF in forum MetalWork Discussion
    Last Post: 12-30-2009, 12:21 AM
  4. SS 304 sheets milling dry or with fluid coolant mist
    By Vincent82 in forum MetalWork Discussion
    Last Post: 11-18-2007, 05:40 AM
  5. Cutting fluid
    By sleeper142 in forum Haas Mills
    Last Post: 07-29-2007, 02:05 PM
