Character:
It is use new technology, a revolutionary new laser platform uniting the with best design. It adopt the highly concentrated energy from a very parallel beam of light, focused to a microscopic spot, which is moved over the marking area to create a variety of images on a wide range of materials – it like a pen write on the paper.
• humanity-friendly operation pannel
• Fully compatible with all current versions of Windows operation system
• Fast file send to the laser
• Multiple file input formats
• Two dimensional codes including Data Matrix
• File input programming (Mail Merge)
• Date coding
• Fill editor
• Motion control (four Axis)
• Multiple input/output interface
Application industry and material: it widely use in aviation and space flight parts, electronic component, metals, kitchen facility, sanitary ware, watch and jewelry, auto and cycle parts, golf hold, sensor instrument, computer, cell phone press key, medicine instrument, cigarette, cosmetic, clothes parts etc.
Can be carved metal and a variety of non-metallic materials. Used in electronic components, hardware, tools, accessories, integrated circuit (IC), electrical appliances, mobile communications, precision instruments, eyeglasses and clocks, jewelry, auto parts, plastic buttons, construction material, PVC pipe, medical equipment and other industries. Ordinary metals and alloys (iron, copper, aluminum, magnesium, zinc and all other metals), rare metals and alloys (gold, silver, titanium), metal oxides, special surface treatment (phosphate, aluminum anodizing, plating surface), ABS material (shell appliances, daily necessities), ink (translucent keys, print products), epoxy resin (encapsulation of electronic components, insulation layer).
Advantage
1. It Adopts pulsed fiber laser device, output peak power can reach 25kw when pulse width is smaller than 30ns, and it has excellent beam quality M2<1.5 which is close to diffractive limitation.
2. The all-fiber design guarantees the stability of the laser, no need of any collimation adjusting of the optical components.
3. Integrated design of the system makes it more convenience to use, and supply ideal solutions for a wide range of the industry applications,
4. Long lifespan, small size, no need of large water cooling system, only simple air-cooling way is OK. Can still work under some bad environment like impact, vibration, high temperature, or dust.
5. The processing speed is 2-3 times faster than the traditional laser marker, excellent beam quality, small optical spots, narrow marking line, suitable for marking in high precision,
6. Integrated design makes it convenience to maintain, small size can save the working space.
Laser source fiber
wavelength 1.064µm
Max Marking Area 85-350 mm diameter
Max Peak Power 10 or 20 w
Operating Temperature Up to 40° C non-condensing
Control Electronics: 19" rack mounted 5U module
Construction Optical unit fully sealed to IP67
Max Pulse Energy 0.25 or 0.4 mJ
Pulse Frequency 0.1 to 100 kHz
Max Marking Speed Up to 10,000 mm/sec
Operating Modes: CW and Q-Switched
measure 80x60x56cm
Weight 50kg
