586,144 active members*
3,347 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > GWEIKE LF10 metal fiber laser marking machine FOR METAL
    Air cooled cooling systerm,easy and quickly installation,USB contacted with any computer and install softerware easily
    Use interfaces types: text, graphics, serial number, serial number, a d bar code, 2 d barcode, successive signet (optional equipments),etc
    Suitable for: anodized sculpture, hand tools deep carved, aluminum a deep carved, stainless steel surface carved black, IC table sculpture, etc.!
    Advantages: small volume, avoid consumables, flexible degree is high, use 5-100000 hours and hours without power attenuation problem!
    Main parts:
    1.laser head can change manually by wheel
    2.EzCad2.7.0 software&softdog
    3.one set computer
    4.3d removable working table
    5.air cooling system
    6.USB port
    7.10/20W pulsed laser&laser power
    Option parts:
    1.UK SPI 10W pulsed laser&laser power
    2.rotary attachment
    Main specification:
    Laser type:Ytterbium Fiber
    Operation type:Q – switched
    Laser power :10/20w
    Each pulse energy (mj): 0.5 1
    Laser wavelength (nm):1060 ~ 1070
    Pulse wave frequency:20 ~ 80 KHz
    working area 100*100mm/150*150mm
    Attached Thumbnails Attached Thumbnails GWEIKE fiber laser marking machine2.jpg   GWEIKE fiber laser marking machine4.jpg   GWEIKE new rotary attachment.jpg   GWEIKE old rotary attachment.jpg
    cnc router for marble 51*98
    supply with CE certificate.
    1.The machine adopts imported linear square and 4 lines double slider.Larege loading capacity,run stably,high precision,long life, accurate cutting.
    2.The whole machine use seamless steel,bettter rigidity,working table backing steel plate,rigid strength and loading capacity of the machine can be more than 1000 KG.
    3.Constant power spindle motor,powerful cutting intensty, high effeciency.
    4.Good compatibility for CAD/CMD software,including Type 3,Artcam,Castmate,Artgrave etc.
    5.The cooling system for tools improves its life.
    Applicable materials:
    Granite, marble, bluestone, sandstone, thin soft metal etc stone engraving
    Density stone such as granite can be engraved to 3mm repeatedly
    Some stone such as marble, bluestone can be engraved to 3mm at one time.
    Specification:
    1)X Y axis working area:1,300x3,500mm
    2)Z axis working area:300mm
    3)Table size:2,000x4,000mm
    4)Max.speed:0-10,000mm/min
    5)Max.working speed:0-3,000mm/min
    6)Working delicacy:0.02mm
    7)Reposition accuracy:0.05mm
    8)Max.feeding height:300mm
    9)Engraving Command:G code,u00,mmg,plt
    10)Software:Type3,Artcam,Ncstudio software
    11)Max.powerconsumption:6 KW
    12)Spindle:1.5KW/2.2KW/3KW/4.5KW/HSD 1.5KW/HSD 3KW/HSD 4.5KW/HSD5.5KW/HSD 6KW/HSD 7KW variable speed, water cooled /air cooled
    13)Spindle speed:18000/24,000rpm
    14)Work type:stepper
    15)Weight:1200kg
    16)Working voltage AC380V,50/60Hz
    17)Memory:32M
    18)Manner of receiving data:USB orPCI
    19)Running circumstance temperature: 0 - 45°C
    20)Relative humidity: 30% - 75%
    Jinan G.Weike Science & Technology Co.,Ltd.
    Laser engraving machine|Laser cutting machine|CNC router-G.Weike Laser
    Tel:+86-0531-88020976
    Mobile:8615154147619
    Fax:+86-0531-88912386
    Email:[email protected]
    Attached Thumbnails Attached Thumbnails GWEIKE DSP(USB) offline control system.jpg   TAIWAN HIWIN square linear rail 25mm wide 4,slider.jpg   GWEIKE stepper driver including USA CMOS chip.jpg   GWEIKE stepper motor.jpg
    GWEIKE tools,collects.jpg   GWEIKE original UcancamV9 english software.jpg   GWEIKE standard lubricating oil system.jpg   GWEIKE cnc tool length sensor.jpg
    GWEIKE dust collector and dust collecting bag.JPG    GWEIKE water pump and pipes.jpg
    51*98 woodworking cnc router
    Supply with CE certificate
    1.The max travelling speed can reach more than 30 meters/minute,the max cutting speed can reach 25 meters/minute.
    2.Adoption of advanced DSP CNC system and make the operation more convenient.And its design provide more human nature.
    3.Unique intelligent caculation rules can fully develop the potential of the motor,it also leads to high speed processing and the synchronization of curves and straight line.
    4.Y axis adopts double motor driver.
    5.Six districts vacuum table.
    6.Professional 3D control system.
    7.Equip CHINESE/HSD spindle motor,vacuum suction table,vacuum pump and dust collector.It is mainly applicable in the manufacture of furnitures,the wooden doors,pvc and other materials.
    Specification:
    X,Y axis working area: 1,300 x 2,500mm
    Z axis working area: <200mm
    Table size: 1,450 x 2,120mm
    Max. speed: 0 - 30,000mm/min
    Max. Working speed: 0 - 20,000mm/min
    Working delicacy: 0.015mm
    Reposition accuracy: 0.05mm
    Max.Feeding height: 200mm
    Command: G code*. u00*. mmg*. plt*. nc
    Software: Type3, Artcut, Artcam, Ncstudio software
    Max. power consumption: 3KW
    motor Spindle speed: 24,000rpm
    Work type: stepper (Option:servo)
    Working voltage: AC 220V, 50/60Hz
    Memory: 32M
    Manner of receiving data: USB OR PCI
    Weight:1400kg
    [email protected]
    cnc router for marble/for wood
    [email protected]
    Attached Thumbnails Attached Thumbnails WK1218 cnc router for marble.jpg   WK1325 cnc router for wood-2.jpg
  1. Thin metal laser cutting machine- CHEAPEST metal laser cutter
    By Gweikelasers in forum News Announcements
    Last Post: 03-06-2013, 10:08 AM
  2. GWEIKE NEW THIN METAL LASER CUTTING MACHINE
    By Melody-gweike in forum News Announcements
    Last Post: 08-10-2012, 05:16 PM
  3. LF10 Fiber marking machine
    By SPC-laser in forum News Announcements
    Last Post: 08-02-2012, 09:02 AM
  4. laser marking machine for metal
    By JennyYin in forum News Announcements
    Last Post: 07-06-2007, 05:07 AM
